- Windsor, CO NEC: 2023
- Hospital Master Electrician
I believe I would have much company in the forum when I say I am not familiar with that document, so an explanation would be appreciated, if you are so inclined.kingpb said:I assume you are then familiar with 142, which in fact, is were I believe the NEC takes it's que, and If familiar with it, then there should not be a question as to why 25 ohm is safer then 50 ohm.
Edit to add: When questions are posted regarding grounding, I attempt to give more specific information than "Check the NEC," or "Look at Article 250" when there is a specific section that clarifies the concept or rule in question. It would be beneficial if you could post some material from that document to clarify your point, as I imagine many do not have access to it.
Thanks,
