romex jockey
- Vermont
- electrician
They were a lot better when they all had GFP as part of the device. All of the original branch circuit and feeder type had GFP. At least two manufacturers no longer have GFP in their combination devices.....
So in summary....do AFCI solve everything. Heck no...are they better than nothing, yes my opinion and no in yours....i can accept that.....can YOU?
it appears to me that they would be much better at detecting and clearing a high resistance or glowing connection fault, before a fire started if they still had a 30 to 50 mA ground fault trip. Now you must have at least 5 amps of current for the device to look for a series fault. You can produce more than enough heat from a poor connection to start a fire with a lot less than 5 amps of current.
For the record I did have a proposal to require this, but it was rejected because the CMP says that belongs in the product standards. There have been many cases in the past where the NEC has driven the product standards and this should be one of them.
Why?.....am I not able to provide my opinion openly? Oh that right....I don't live in the real world...lol..because the electrons change over time...Got It...
Thousands eh....hmmm....i see the same folks on these threads as I always see....not thousands...![]()
We should just have GFCI/AFCI main breakers, one fault and poof your entire house is without power. Safety first!
For the satire impaired, I am being completely sarcastic, however I think that's where we're ultimately headed
Yeah, I'm actually confident that THOUSANDS of ECs have dealt with AFCIs since their inception.
I would imagine that most ECs would waste no more time impotently complaining on an Internet forum than logging into AFCI websites to help manufacturers with perfecting their snake oil. No forum member's participation revolves around AFCI.
I didn't ask you to carry water for the manufacturers in this thread; you volunteered and then failed.
LOL..Typical George....Yeah I Failed....Classic Mod
I would celebrate a main breaker AFCI requirement. It would kill the requirement in the first month.
J, sensible as the idea is, to do so would be tacit acknowledgement that their technology sucks. They'll never do it.
I don't think any of us are against afci technology on paper, and in theory.
Your reading skills are above this. Look again, that is exactly what happened. You need a new prescription of eyeglasses that filter out your ego when you post, they would save a lot of foolishness.
As I clearly said; just because an AFCI breaker tripped does not mean that a standard one wouldn't. You offered no proof, just rhetoric.
The technology sucks, the idea does not. Although I'm not a Gambling Man, I would bet that in my lifetime that smart Breakers will replace afci, and it will be a distant bad memory, like aluminum wiring in the 70s.
