This was passed on to me via a Friend of mine. Not sure were he got this from.
Some interesting tidbits of info: firmware for us is basically thousands and thousands of lines of computer code that generate some type of mathematical 'signature' wave form - this is how we are able to program the breaker so quickly and easily and tell it how to identify good and bad arcs, for example; or replicate what
appliances are doing to the sine wave signature. But UL 1699 does not to my knowledge have in
its 150 or so required tests anything to address compatibility with appliances.....so we can only test to what we have standards for in UL 1699.
Also think about this: the CAFI breaker does something like 3.2 billion diagnostic checks of the circuit every year and determines if it should trip. That is a lot of diagnostic programming capability in one breaker!!!
I believe actually NEMA is one taking up the topic of addressing all of these issues with the appliance manufacturers. For instance I think most plasma screen t.v.'s violate FCC emissions standards for residential yet as you point out the breaker takes the blame because it tripped on something it was programmed to do or is outside the realm of FCC standards, UL, NEMA, etc We do our own research in our labs. basically if we can replicate something an appliance is creating then we have successfully addressed with changes to the firmware in the digital processor in the CAFI breaker. situations in our labs - and again, if we can measure it/replicate it - then we can address it with firmware changes.
we went into production on what we believe is the last firmware release we will ever have to do to the CAFI programming - and yes we basically loosened the programming as much as we could and still attain UL 1699 but we had to do it in order to
