ronaldrc said:No,no,no
I am the real certified dummy because I don't know the answer to that question.
The Real Certified dummy
flashlight said:This is fascinating.
To my understanding, a GFCI only trips on the load side because it is "monitoring" the current "in" on the hot and "out" on the neutral sides and trips if there is an inequality, indicating a fault to ground.
However, the AFCI, as mentioned in various posts, electronically "sees" the parameters of the sine curve and reacts to deviations which fit the "signature" of an arc fault. (Pardon so many quotes but in a sense we are anthropomorphizing this process.) By this reasoning, as other people have pointed out, the device should trip with any arc fault in series with the current, whether up-or downstream.
Looking forward to hearing from someone who actually knows what they are talking about ! (I mean in comparison to myself, not you guys who posted earlier !)
ronaldrc said:Well nemo
We can get by with just using one AFCI now because someone that knows what there talking about says it will trip with line side faults,how can the inspector argue with that![]()
flashlight said:I'm just following up on some thoughts from previous posts. If what AFCIs do is monitor the sine curve, an event upstream would change that as surely as one downstream.
But that's certainly not what they are designed for. Do they work that way ?
Not to my experience, but arc fault conditions on the line side are probably much rarer than on the load side.
At any rate, I should take my seat. I was just joining in the conjecturing here (see previous posts), and I've never seen a diagram of how an AFCI is built.
ronaldrc said:Nemo
I'm waiting for some who knows that for sure to speakup.
Do you know for a fact there is a chip that rejects the arc signal from coming in on the line side?![]()
480sparky said:No, you will still need a panel-full of AFCIs. If a fault upstream of an AFCI can cause one to trip, then you need them all to trip in order to make sure the circuit that's affected is shut off.
Well OK that makes sense too.
But sinewaves only flow between the load, or cause, and the source. The sinewave of one circuit has no bearing on any other. If that were the case, then simple circuit breakers would be affected the same way.... overload one, and they all trip.
ronaldrc said:We are talking about a signal created by a spark and impressed on the wiring.![]()
