wwhitney
- Berkeley, CA
- Retired
That's right, it doesn't exist. Your reading adds the word "branch" in front of circuit willy-nilly. As a first draft, I would say a circuit is "some conductors going to and from an Outlet".Would you care to point out the NEC definition of "circuit", especially as contrasted to "branch circuit"? It doesn't exist.
Those are all circuits. And the fact that a Feeder is a circuit shows you can't just substitute "Branch Circuit" every time you read the word circuit.Are you saying a branch circuit is not a circuit? A feeder is not a circuit? A control circuit is not a circuit?
The gray area is that the second requirement does not use the phrase "Branch Circuit". So is the word "circuit" there just shorthand for "Branch Circuit"? That seems to be your reading. Or is the requirement just saying that the voltage supplied to the receptacle has to match the receptacle's rating? That's my reading, and that depends only on the part of the circuit the receptacle is connected to, not the rating of the Branch Circuit as a whole.404.6 tells you that a receptacle SHALL BE INSTALLED in a branch circuit. 404.6(A) tells you a grounding type receptacle SHALL BE INSTALLED in a circuit of the same voltage class as the receptacle. There is no gray area there.
Again the undefined term "circuit" is a more flexible word than the defined term "Branch Circuit".
Cheers, Wayne
