peter d
- New England
Thats pyroforic carbonization mostly. I guess it eventually wore down enough insulation eventually on the hot to contact the EGC.
Did you read the thread? I said that already.
Did you read the thread? I said that already.![]()
It won't sadly, the leakage is resistive. IMO I think this is a perfect example of why work quality will out do any safety device ever mandated.
Right, it's current flow into the wood. No actual arcing is taking place. AFCI one again proves how worthless it is.
I was going to ask how many years it may take for this to happen, and figured it would have to be in the decades ranges. Then you mentioned the lightning strike situation and how it may accelerate things. Seems lightning could accelerate this even if there isn't an over driven staple involved.Its microamps from what I've heard. Enough to heat the wood over the course of years if not decades ever so gradually.
But not worthless to the AFCI myth. It was this very hazard that was spun around into arcing giving birth to the over driven nail theory. The over driven staple weakens the insulation enough to not dielectric break down, but enough so the lightning strikes and surges "punture" the weak spot. That weak spot then arcs on 120 volts and in a short amount of time the stud ignites- hence a perfect (on paper) explanation why over driven staples take years to show up. But the reality that UL and every other AFCI pusher chooses to ignore is that the staple or nail is live with 120 volts since day one. Arcing and short circuits are the end stage when the wood finally starts to smolder and burn from pyroforic canonization- not the start. Greatest spin ever told...
I think the risk of starting a fire with a lighting fixture mounted on a wood surface or a recessed can in contact with wood would be a higher risk. The heat dries out the wood over time and lowers ignition point, you have more heat here then you woodwith the microamps flowing in the conductor to wood fault situatiuon.
I should have said a non IC can.:huh:
An IC can is suitable for insulation contact, often the paper face on the insulation is in contact with the light especially in new construction. I've never heard of the paper catching fire, let alone the wood.
I know the concept is hard to grasp, but keep in mind the Grand Canyon is said to have been created entirely by erosion (mostly water) over millions of years.
Been years since I used to buy both IC and non IC cans , only difference between the two that I was buying was they had different thermal protectors so I would assume trip point of the protector was at a different temperature. The non IC cans were generally rated for higher wattage lamps in same trim then if using a IC rated can, but if installed properly should be able to dissipate the extra heat safely.
I have seen charred wood behind surface mount fixtures before - especially if it were subject to too high of wattage lamps being installed.
Give many millions to breaker manufacturers at the expense of ECs and their customers, while significantly eroding confidence in the objectivity of the CMPs! Yay!So what is it they do exactly? :?:roll:
So in summary, an AFCI cannot detect:
1) A glowing connection
2) Pyrophoric carbonization taking place
3) A ground fault under 30 milliamps of current flow
4) Any fault current flow at all in some models where there is no GFPE whatsoever
Both better replies but sort of on same path that what I was going to mention:So in summary, an AFCI cannot detect:
There is a theory that if you keep your money in a hole in the ground, it does no one any good.![]()
There was no dimes involved, mostly $50 bills.:thumbsup:
Don't forget the decade plus of free R&D the manufacturers got on the customer's dime.
Honestly, at this point it seems completely inexcusable to me that they don't....At this point we can only hope they work better....
