- Chapel Hill, NC
- Retired Electrical Contractor
That is exactly what we do. I don't see a grounding electrode conductor in the pictureAll the POCO around here would allow us to run a GEC from the meter to the ground rods, no tapping or multiple runs to each panel.
I'm curious how the OP connected the conductors from the 3 200 amp mains to the meter socket. I've only seen 320 meters accept 2 conductors.
I’ve got boxes of two hole and three hole spades we used to give away to electricians. Haven’t had anyone ask for them in a couple of years..You can see the pics in this thread. I did have to change the lugs to 3 conductor lugs. I had to order it thru the power company as the supply companies could get them. They gave me the lugs
600 amp residential service change
my dilemma is still should I upgrade this split buss 400 amp service to a 400 amp non split bus panel . He`s got about 9k sq.ft. and is adding about another 3k. and a bowling lane in future. I know I do need to do the the load calcs now , he has gas , I just have to please the inspector. Why...forums.mikeholt.com
Think I may even have a few four hole spades.
I wasn't saying there wasn't one I just didn't see it. I guess I could've blown it up some.... Anyway I believe he only had one rod
He also said that I needed 2ea grounding rods (one on each end of the meter rack) instead of just one.
He also said that I needed 2ea grounding rods (one on each end of the meter rack) instead of just one. I know that you need a ufer ground, and a ground rod at the house, but this is a meter rack that is not attached to the house. It is in a field several yards away from the house.
I believe all of these items aren't necessary according to the code book. Am I correct?
