kwired
Electron manager
- NE Nebraska
- EC
You are absolutely right, many of us are knowledgeable enough to realize what problems may exist with this install, and even know of some possible solutions. IIRC OP wanted to know if changing the blower speed would solve his problems, to which many stated yes but it would likely create other problems. Other then to explain what the nature of those problems may be, that is about where the electrician advice should stop and the HVAC advice should kick in. There are some people well qualified in both areas, their input is valid on both sides of the situation.Nobody claimed they're "qualified", that's for sure! People learn by asking others, and that's probably the biggest reason why Mike put up this forum. One came with a question, and we tell the guy there's a solution. How he does it, it's his thing. Pray, tell me that ain't so?
Another possible solution not mentioned is to dump a certain amount of conditioned air outside - but that really has a negative effect on efficiency and the amount of utility bills
