kwired
Electron manager
- NE Nebraska
- EC
If thermal insulation is causing light to cycle on and off you either have too large of a lamp or a non insulated ceiling rated fixture.
Add to that defective thermal protector, stuff happens.
i didnt take the offending overload out and analyze it, i just moved the insulation away and problem solved. i think we all know a can lite always says @65W max. okay, well never say always, but i put all the lights in this house in, and light bulbs. i can bet you the overload was made in china. land of the utmost in quality control
All the fixtures I can recall the max lamp size is not determined soley by the can, it is usually a combination of whether the can is an IC or non IC can, type of trim, and type of lamp that determines max lamp size. You can usually use a larger reflector type lamp than you can use a type 'A' lamp, the reflector lamp radiates more heat downward than regular lamps.
Prescolite cans I used to use were identical between the IC and non IC cans except for the thermal protector - I'm fairly sure the temperature setting of the protector was the only difference.
