Interesting, you remove and re-torque without trimming?
IMO that is not a great way to go. :smile:
iWire,
I understand that the NEC may not "require" anti-oxide, in general. Having repaired alum wire fire damage (as you probably have also), I don't enjoy the damage caused, and protential for fire.
Here is my method (derived from the Aronstein website):
(1) remove the connector,
(2) re-dip,
(3)
(a) scrape off with pliers,
(b) cutting into the anodized alum oxide
(c) pulling anti-ox directly into the fresh surface.
I've tried to read everything there is about this subject
and just don't think there is bullet-proof method of handling aluminum. Combining that with a copper wire in the joint just adds to the potential problem. I have repaired #12 circuit joints (like most everybody), and Service Lateral Crimped joints, and Larger cables terminated in large circuit breakers, and Service feeders from the Meter and Service feeders into the Main Lugs panel, and Service Risers feeding into the top of Meter sockets. All the above refers to Aluminum cabling. I wonder if there is a problem here?
There are some methods, other than Anti-Oxide, and I've tried a few.
I like the Copalum crimp connector, but at $3. per joint (#12 size) and the $1000 crimper tool required by Tyco, I just don't see that as being economical. At least not on small jobs, or single unit repairs. The one I have used is made by King. King has a alloy block with three holes, three set screws and filled with silicon, all in a neat plastic flip shell. I've used King connectors to do 45 recepticals in a house, for one example, and they worked OK. King connectors were about $2.00 each.
On the other hand,
the inconsistent use/nonuse of Alum Anti_Oxide helps pay my rent.
I try to bill for my repairs.
I do wonder why there is not a clear cut mandate from NEC to use the Anti-Oxide. There must be a good reason for NEC's position. Wire manufacturers don't want to say there may be a potential problem with their product, its installation by electricians, or its being affected by some environmental factor.
So, "who" is to say?
Maybe, the Consumer Product Safety Commission?
Maybe, Underwriter's Lab?
Maybe there is NO problem, after all.
Just our imagination?
And, I'll keep making a little money fixing the fire damage.
Comments are welcome
