mark32
- Currently in NJ
Over the summer I installed 6 low voltage path lights along with the associated items. I received a call saying that none of the lights were working so I stopped by today to check it out. GFCI that trans is plugged into, good.
Timer that operates the GFCI, good.
Trans output, 12v's
One splice I made connecting two runs together, good.
I was stumped, I pulled one bulb, visually it looked good. Meter says I have 12v's at socket, huh? Switched meter to continuity and checked bulb, bulb no good, huh? I checked another and the same thing, so I replaced two bulbs because that's all I had. How is it that all the bulbs could blow in one night? I am guessing a power surge could have taken them out, is this a viable theory? There are a number of line voltage lights on the same circuit that feeds the transformer but those are all okay.
Trans output, 12v's
