xguard
- Baton Rouge, LA
Can LFMC only be used where flexibility, or vibration isolation is needed? I've heard this is the case a few times but haven't found where the code clearly states this. An example I've seen recently: Rigid Galvanized Steel conduit > LFMC > Rigidly Mounted Disconnect > LFMC > to motor. According to this view the LFMC between the rigid conduit and the disconnect would be in violation but not the LFMC between the Disconnect and the motor. Thanks in advance for any feed back.
