Bjenks
- East Coast of FL
When running Aluminum service or feeders I have a couple of questions about what is a better design or typically done in the field:
1) While 250.64(A) does allow Aluminum GEC in certain situations, does anyone every use Aluminum or is it best to just always use copper for the GEC?
2) While 553.8(C), 555.15(B), 680.23(B)(2), 680.25(A)(2) doesn?t allow Aluminum EGC because of corrosion and MC All Purpose uses Aluminum for the EGC, if Aluminum is specified as the current carrying feeder conductor do you typically still use copper for the EGC or keep the metals the same?
I ask this as I typically go either all Aluminum or all Copper when I do an electrical one-line (actually I might do Aluminum service and then copper feeders). However, when I go in the field I see a lot of copper EGC installed with aluminum feeders. So I wonder what is typically seen out in the field and from other designers?
