Cavie
- SW Florida
How about the mods pick out a good DIY site and referance the DIY to that site.
Some of the things that an engineer would do in the design phases of an electrical project are also learned in the training phases of an electrician's career. There is a legally-drawn line that establishes when an engineer must be involved in the design, and when an electrical contractor can handle the entire installation as a "design-build project." So if an electrician posts a question about performing load calculations, there is a good reason to anticipate that this is part of that person's normal job duties.But it does seem like a double standard. Electricians can ask engineering questions, but not the other way around?
Nah, it's been discussed. The liability for the advice from the other site could be shared with ours.Cavie said:How about the mods pick out a good DIY site and referance the DIY to that site.
We talked about that (debated, actually) several years ago. The consensus is that we should not do that. The reasoning, weak as it may be, is that if answering a DIY question risks a lawsuit (as in, "you should have told my client that he needed to xxx, when you were answering his question about yyy"), there is also a risk of a lawsuit if we suggest another Internet information source (as in, "you recommended that site to my client, and my client received poor and insufficient information, and you should have known that that site would not give enough good information. . . ").How about the mods pick out a good DIY site and referance the DIY to that site.
By contrast, none of the things that an electrician would do, from "means and methods" to the NEC itself, are taught in an engineering degree program. There is no reason to anticipate that a person with a BSEE knows anything at all about safely performing electrical installation work.
So conversly electricians should not be performing design or engineering work and should not ask for help in those areas?
In the Mike Holt forum, the Mod Squad is the AHJ.
I'm still getting much more than I give, so thank you all that give more than you get!![]()
You're welcome!I'm still getting much more than I give, so thank you all that give more than you get!![]()
Conversely, I do not hear a whole lot of stories about electricians engineering their own work and it resulting in a hazard revealed later to an engineer.
Do you at least read this list that manifest some of the utmost and fundamental ignorance of people who call themselves electricians and licensed so by a State?
Could you point to where that line is laid down in writing?
I once worked for a design-build electrical contractor. They had a small internal design group that would provide the basic plans for many types of buildings, and the electricians in the field would make the detailed decisions as they were doing the installation. That was allowed by Washington Admin Code for some types of facilities, such as retail and residential. But other facilities had to be designed under engineering supervision. One example is that the State of Washington requires a plan review for the design of new health care facilities. The plans are required to be sealed by a licenced PE.Could you point to where that line is laid down in writing?
There was no course in either my BS or MS degree programs that mentioned the existence of the NEC, nor any that discussed the difference between THHN and THWN. So I don't understand the reason for your strong disagreement. In an engineer does have any knowledge or skills in the arena of electrical installation work, it was not obtained in a college EE degree program. A person working towards a BSEET degree get more hands-on experience than a person working towards a EE degree, so I wonder if that is what you are refering to.Stronlgy disagree on both counts.
charlie -There was no course in either my BS or MS degree programs that mentioned the existence of the NEC, nor any that discussed the difference between THHN and THWN. So I don't understand the reason for your strong disagreement. In an engineer does have any knowledge or skills in the arena of electrical installation work, it was not obtained in a college EE degree program. A person working towards a BSEET degree get more hands-on experience than a person working towards a EE degree, so I wonder if that is what you are refering to.
My state follows the model law - as do most states - but possibly not MA. In short (loose translation), if the work involves product of engineering, for hire, and is for buildings (structures) for public access, then a PE is required. What you described in your post on metering CT would be technically illegal, but highly likely that would not be enforced.In my state electricians are allowed and expected to do design and rudimentary engineering. It is part of my job...
I would agree with the electricians doing that.... But at the same time it is a fact that electricians must do some designing / engineering or they will not have a job. ...
That's absolutely correct and I agree they shouldn't. Nor should they hire an electrician for every electrical job.... Customers are not going to hire an engineer for every electrical job.
If it's inane, why has the thread lasted as long as it has? It was answered by "one with a hammer" in the second reply, IIRC.What I don't understand is why the moderators are defending their decision. You (plural) are the ones with the hammer. You don't have to defend your inane decisions - you just have to live with them.
