ceb58
- Raeford, NC
Maybe I should invite one of the state inspectors for the reinspect.....:grin:
I would drop the maybe. Replace should with will. And forget the smiley
The electrician was a little upset due to the fact I found several other violations and stated there would be a re-inspection fee.
he didn't have 1/2 of the first floor even pulled never mind made up and since this was a 5000 sqr foot house, thats quite a bit of work left to do.
I would seriously be looking into his license. Was this the master or 1 of his 1st year green helpers. I would send a copy of the pictures to the state. Not only are they violations but shows he has no clue of what he is doing. On return inspection i would pack a lunch and give him the inspection of his life.
Was this the master or 1 of his 1st year green helpers. .
Interesting that in the two pictures taken one is before all the branch circuits
were connected the second after the connections were made, did the EC give you progress pictures of the job or did you take the pictures and if so did you mention the violations after the first picture was taken?
Without a doubt, in my mind, those are pictures of 2 different panels. This probably is a 400 amp service. The plywood to the left of the first picture has 5 knots in it. The other panel does not have any knots-- thus they must be different.
Is it required?
Couldn't really tell from the picture, but it looked like they didn't use anti-oxidant either.
Is it required?
Looks like aluminum in picture. If it is copper, then no.
What does this mean. Are you saying the manufacturer requires it? I didn't think the NEC required it.The NEC does not directly require the use of anti-oxidant.
I have seen GE disconnect switches that specifeid the use of the paste when AL conductors where used.
Thank you - that explains it.
Shame on me for not calling you and asking what panel I should use.:roll:Shame on anyone that uses GE panels and breakers
