e57
- San Francisco, CA
bikeindy said:AAAAAHHHHHHH! I thought this thread was dead.
It's alive!
Let the "20a is better" game begin.....
I bet this apparatus is not on #14!e57 said:It's alive!![]()
Ed Carr said:aaaaaannnd cut!
ryandumas said:He claims that a den or living room is a similar room to a breakfast or dining room etc.
ryandumas said:Update I talked with the head inspector and he told me to look up 210.52 a
He claims that a den or living room is a similar room to a breakfast or dining room etc. I then replied all the rooms involve food in some way cooking it eating it and so on so how can he compare a den with a breakfast area. Anyways I needed to get the job done so I changed got paid and left
In theory on a general use circuit a 14 gauge wire protected by a 15 amp breaker is more safe then #12 protected by a 20 amp breaker. Most of your aappliance cords are rated for apprx. 7 amps. So if you had an over load problem the 15 amp breaker would trip faster.ITO said:You would have gotten a red tag in my area too, our local building criteria does not allow 15 amp circuits or receptacles for convenience outlets in residential housing. Check the local building criteria in your area, it may not be NEC but the AHJ may have another set of rules.
buckofdurham said:In theory on a general use circuit a 14 gauge wire protected by a 15 amp breaker is more safe then #12 protected by a 20 amp breaker. Most of your aappliance cords are rated for apprx. 7 amps. So if you had an over load problem the 15 amp breaker would trip faster.
See if you can find out what kind of vacuum was being used and/or the amp draw. Just for curiosity's sake, I was wondering if it is a standard model or an unusually large/rare/expensive model (not as rare as the VCFH, of course). It might determine if something is wrong with the vacuum or if something is wrong with the wire size.Tiger Electrical said:I had another client complain that the circuit breaker tripped while vacuuming on a 15A circuit today. I knew you'd want to hear about it.
Dave
Dave, If anyone is in the service end of the business that is not a rare problem. pretty common, for owners of a good quality vacuum cleaners, the amps are up there, then the portable space heater is another, along with the entertainment centers with the plug strips, loaded to the limit, code min is great for production work where price controls the design. We use 14 for lighting circuits, on many projects, but on custom homes we take care to avoid min design, the custom owner is more likely to buy high end equipment, $490 vacuum cleaner rether then a $139 modelTiger Electrical said:I had another client complain that the circuit breaker tripped while vacuuming on a 15A circuit today. I knew you'd want to hear about it.
Dave
Dave
georgestolz said:Don't trail off there, and keep me in suspense! "...in accordance with..." what?![]()
The local AHJ in Indiana does not have the right to change the NEC; however, the State of Indiana does have that right. In the adoption process, the State of Indiana adds the Indiana amendments to make the IEC (Indiana Electrical Code). Many (most?) of our electricians and building officials are not aware of the IEC but they are aware of the NEC.ITO said:Don?t know why but my local AJH has been publishing their own criteria in the form of an electrical code via city ordinance since before I can remember. This criteria supersedes the NEC, and causes problems from time to time with out of town (or state) engineers who are not familiar with it.
bikeindy said:I have an industrial vacuum that doesn't trip a 15 Amp circuit. the design is bad not the wire size or breaker size.
