Am I nuts or is this job done as per NEC.
I have been doing tank farms for a good part of 30 years + contact cement manufacturers ink rooms and all kinds of XPROOF stuff. I was asked to do the controls and tank gauging on this small install consisting of 3 10K tanks 1 gas and 2 kero in a concrete containment/enclosure 4 walls and roof, with maybe 3' from the walls and 5' to the roof-1 12' roll up door and passage way door. and when you are dealing with gas I get nervous, I see die cast offset nipples, 3 piece unions and no sealoffs on switches (that are not factory sealed) and leveing the room to go to a panel board. I asked the mechanical contractor that hired me and he said the inspector pased the job. So I am wondering if I have been losing money for years by using expensive fittings and stuff when it was not nessesary
ATTACH]2199[/ATTACH]
