badshah
- United Arab Emirates
Hi,
We experience copper theft in our substations, usually the surface mounted copper conductor for earth or earth cable connected for bonding between equipment (RMU, Transformer & LV panel) were stolen (some instances even ground electrode were also stolen).
My Question: Is it possible to conceal this surface mounted ground conductors or cables within concrete i.e. the conductor run will be within the concrete not exposed? Instead of exposing the ground conductor, if they are concealed within concrete, will the conductor serve the purpose of grounding?.
Also i found there are some Conductive concrete available in the market, which protects the conductor from corrosion unlike normal concrete, also reduces impedance and enhances the performance, reliability and longevity of grounding systems.
Thanks & Regards
Badshah
Thanks & Regards
Badshah
