Any problem using NM with OSB walls?
wawireguy
I was wondering if there was a fire rating issue with using NM in walls that will be sheathed with OSB on the interior. I know there is supposed to be a 15 minute finish rating but am unsure if this is even a issue. Thanks!
The 15 minute rating only applies to "other than dwelling unit"
What is this?
Here is a link you may find useful.. I'm sure the same information is available from the co. that made the OSB your planning to use
OSB panels made by member mills of the SBA meet
the maximum flame spread requirements of the National
Building Code of Canada or the U.S. Model Code
requirements for interior wall and ceiling finish.
Depends where it is,.. in Massachusetts if it is an accessory to a dwelling good to go with nm. In 2011 it will also most likely be alright with the NEC
http://www.iaei.org/magazine/?p=4488
I'm good to go, I just like to dig in to a job. I want to know everything I can about it. There is a point where you know it will fly and you just get it done. That's where I'm at.
