hockeyoligist2
- close to greenville sc
Thinking about buying one. Like it or not? Good points, bad points?
Got one. Like it. I think it is worth the money.Thinking about buying one. Like it or not? Good points, bad points?
Not until you pry it from my cold, dead hands.You'll throw away your solenoidal tester in no time.
Had one for years and wouldn't give it up, but don't throw your wiggy away. Phantom voltage will get you otherwise.
If the vibration mode is the only thing holding you back, if you don't mind voiding your warranty, a little surgery ought to take care of that!Some of you are losing me and others. The T+ and the T+Pro ARE low impedance testers.
http://us.fluke.com/usen/Products/solenoid
Con for me: I don't like the vibration mode, it isn't selectable. Gloves or not, I never liked the thought of something vibrating in my hands working live.
If you expect it, that's one thing, however...Con for me: I don't like the vibration mode, it isn't selectable. Gloves or not, I never liked the thought of something vibrating in my hands working live.
It's not switchable? It is on my cellphone.If the vibration mode is the only thing holding you back, if you don't mind voiding your warranty, a little surgery ought to take care of that!
What was the point of doing that?The T-Pro along side my VOMs is low impedance. Placed on the same test points as my VOM, the readings are almost the same. Place another VOM on those test points and there is no change. Place another Tpro on the circuit and the voltage drops in half, then again for the third Tpro. This was on a very special motor control circuit that I hope to correct some day.
I suspect the current draw of a wiggy is considerably higher than the TPRO.
