Riograndeelectric
- Lakewood Colorado
the code requires any oultet in a bedroom be on an arc fault cicuit. what do you do when adding a new light or outlet in a bedroom that is wired before 2002 and was not required to be AFCI protected. Would you go and change out breaker on exsitng circuit so it was AFCI protected or would you go ahed and tap off existing circuit add new light or recp with no AFCI protection
