arc fault requirements
To more fully reply to your question. All the outlets on the circuit have to be arc fault protected, this includes lighting outlets. An inspector that tells you that a lighting outlet is to be protected is correct. Also, the entire circuit shall also be protected. :)
"210.12(B) Dwelling Units. All 120-volt, single phase, 15- and 20-ampere branch circuits supplying outlets installed in dwelling unit family rooms, dining rooms, living rooms, parlors, libraries, dens, bedrooms, sunrooms, recreation rooms, closets, hallways, or similar rooms or areas shall be protected by a listed arc-fault circuit interrupter, combination-type, installed to provide protection of the branch circuit."
I wish similar rooms or areas was removed. IMO that leaves to much to to opinion.
I wish similar rooms or areas was removed. IMO that leaves to much to opinion.
