If we install a new electrical panel
(fed out of an existing panel in existing building)
I know NEC requires new arc flash label for
it. We had note on plan for contractor
to carry this task (i.e hire 3rd to do arc
flash calculation and print label)...
my question is what is the limitation
for this arc flash calculation in order to
get the arc flash label for new panel?
Or how to perform arc flash calculation
for existing building?
It appears this will be huge cost issue if the calculation
will need total fault current calculation for entire electrical
distribution first in order to calculate arc flash level
at new panel level...
In future, if we want to add more new panels...
Will 3rd party start over the whole fault current
calculation again and then do arc flash cal.? Does NEC
have any exceptions for existing building in this case?
Thank you.
Thank you.
