ken44
- Austin, TX
Is there an exception that allows the wire feeding the service main to pass through another panel without being fused?
Heres the situation: The meter is on the left, then the main panel to the right of the meter, then a sub panel, then the service main. The wire starts at the load side of the meter, then passes through the main and sub panel into the service disconnect and from the service disconnect back to feed the main panel.
