Steviechia2
- Massachusetts
I used to think that myself, but read it carefully, exactly what the wording is intended to mean is not that clear at all. It can be interpreted to mean no nails or screws in the sides of the box at all except for the back 1/4 inch of the box sides. This makes some sense for narrow device boxes where device terminals may be real close to contacting the mounting screws. Makes no sense at all for something like a 24x24 pull box, but as worded it applies there also.
So the answer to your question if you are confused with all the posts:blink: is no. You cannot use a a typical plastic box mounted with screws inside of the box (see post 17) unless it's a listed box
I think you will find that most electrician's do as you proposing which IMO is not a real safety issue.
