jxofaltrds
Retired ESI
- Mike P. Columbus Ohio
- Creator
Re: Attic acess clearence?
Drill what!
I hope you do not drill trusses.
Mike P.
Drill what!
Mike P.
Please, PLEASE do not drill trusses!!!Originally posted by macmikeman:
[QB] You can allway's drill thru the trusses (I'd keep it to a 1/2" hole) and run the wires thru the holes.
What made these joists special? Or, did you drill in the restricted portion?When I was a first year apprentice, I was asked/told to drill the floor/ceiling joists for the HRs across a residential building. <snip>Well... they had to replace every joist I drilled. <snip>
Perhaps the answer to your question is in the question itslef..."from a layman's standpoint". I am not interested in layman's standpoints, only structural enginner's standpoints. No offense.Originally posted by awwt:
[QB] From a layman's standpoint I would understand not drilling through trusses if trusses were made of clear lumber. Most trusses are made of construction grade lumber and that lumber is allowed to have knots up to 1". Is a 1" knot much stronger than a 1" drilled hole?
A 100+ year old commercial place my dad bought some time ago had numerous mods over the years. One was to extend the foundation out along one wall for an addition. The existing joists were old rough cut 2x12 and plenty sturdy...until the guys who did the foundation extension (50-70 years ago) notched'em at the ends to where they were only about a hands width wide sitting on top of a brick wall built between the old and new sections.Originally posted by iwire:
I do not believe any building inspector is going to be happy to see a notch in a floor joist the bottom half of a floor joist is also under tension.
Yep, its a bummer. I fixed ours by pouring some footers along the old brick wall, then building fascad style 6" block wall up against the old brick until it was just underneath the cracked joists. Then I jacked'em back into place until the cracks were closed up again (shot some glue in too before the final cranks on the jacks) and lifted'em up maybe an extra 1/16" and shimmed/blocked up from the new fascad wall underneath'em. Then I took a wire brush and cleaned all the crap off'em good and glued and nailed some 12" X 3-4' long plywood scabs on both sides to firm up the cracked area and set'em back down on the new wall. If everything had been nice and open, some sisters and fabricated "U" straps would have been a more straight forward, but this place was chock full of wiring and plumbing that would have had to be moved to slip sisters in. Shutting down the plumbing and electric in an occupied commercial building for any length of time was the wrong answer. I needed something that could happen in real-time with no impact on the tennents.Originally posted by iwire:
Tony when I posted I was thinking of notches in the middle of the span, I had forgotten about notching the ends.
All the floor joists in my 80 year old house are notched as you describe and sure enough some are split.![]()
