Well, that certainly assumes that the wiring will be in conduit in the first place.
Depending on the overall environment you may not be able to use NM anyway.
If the panel is surface mounted in a place where NM is not allowed to be exposed, or the generator is outside, for example.
Tapatalk!
The panel will be in a bedroom. It will be a 320 meter base with a regular panel on the left and this generator panel on the right. I was just hoping to use SER from the panel to a weatherproof junction box outside and then run polytough to the generator. I was hoping to do the same with the control wires but use two runs of 14/3 from the panel to another exterior junction box.
