Fred B
- Upstate, NY
- Electrician
I've seen melted down Twisters, Name brands not TEMU or Amazon. Haven't seen melted down WAGO, can't say it hasn't but never seen, but you got to be careful of the unbranded knock-offs, the WAGO that I use is UL listed to 600V, the knock-offs only rated to 300V and not listed. WAGO while sort of new here has been used since early 1950's in the EU, and has a history of reliability. Great for solid to stranded connections and to allow for testing setup. You can get WAGO din rail and screw down holders to add to an enclosure to neaten an installation. Can't do that with a twister.I haven't taken the time to research them as you have. But I still don't trust them simply based on what I have had to replace out in the field. I think it has to do with heat that is generated with higher currents. I'm sticking with my Ideal Twisters and I'll use the WAGO connectors on ballast changes.
Have had issues with the push-in connectors but that is no different than the back-stab receptacle or switch IMO. Seen testing of all three and the WAGO held up way better than the push-in and just as good as the twister.
WAGO also makes a good straight thru splice connector for when you go in and have short conductors in a box, not going to get a twister splice in a 2x4x3 box with the conductor that does not extend beyond the box, at least not with my hands.
