Went to a service call where the homeowner was attempting to change a receptacle . He had removed the device ( power still on) and shorted out the hot to neutral conductors.
Called saying that power was out in the living room and bedroom but no breakers had tripped.
First thing I checked was the breaker and it was supplying 120V
Figured a GFCI had tripped somewhere. Not a single one in the house.
Started tracing a path where power was off and led me to a living room receptacle. It had 6 wires stabbed in the back and one showed considerable discoloration and overheating.
Apparently the fault caused just enough arcing at that point to break the wire.
I randomly pulled a number of other devices throughout the house and found several that showed signs of overheating.
40+ years of use with several window AC’s being used over that time.
Ended up getting a job replacing all devices throughout the entire house.
