sparky 134
- Joliet, IL
when two ungrounded conductors which share a neutral originate from two different panels ( one from the main panel and one from a generator backup panel ) in which panel should the neutral terminate. the situation is a residential setting and the backup panel is fed from the main panel and the generator via a transfer switch. there is a neutral from the main panel to the neutral terminal strip in the backup panel and also a neutral from the generator which terminates on the neutral strip in the backup panel. electrically speaking, it shouldn't matter which panel the neutral from the network terminates in since the neutral in the main panel and the backup panel are tied together.
