Sean.Day72
- Florida
I live in an old home that is is fed overheard from a pole mounted transformer. Recently the neutral went bad or "loose" on my service. I noticed because my TV started to flicker on/off rapidly and the fridge stopped working. When I touched the fridge I felt a sensation in my arm, like a little shock. I immediately went outside to open the main disconnect and when I walked over the area where the ground rod was I felt a small sensation in my leg..it frighted by dog to. Immediately called my POCO and they upgraded my ticket to "extreme emergency" and I had a guy replacing my triplex feed into my within the hour. I knew the neutral was shot because instead of the neutral current returning to the transformer is energized my ground rod.
Now my fridge, xbox power supply, cable box power supply, and keureg coffee machine are all broken totaling about 3K in damage. Question, why does a loose neutral destroy power supplies? Is it an under voltage thing? Or is it a rapid turning on/off with the loose connection? Also would I have a claim with my POCO to replace these things or am I SOL? How could the casing of my fridge become energized?
