LarryFine
- Henrico County, VA
- Electrical Contractor
And nobody asked about the floor plan. One big room, or a few rooms and a bath? So many variables.
Hi OllyHi James, would you mind sharing the spread sheet you have to these days / current material and labor costs price per line item? If it is easily shareable I would greatly appreciate it
I agree there are a lot of variables. 1K sq ft doesn't tell you very much. Is this thing going to be a small apartment or a big game room?And nobody asked about the floor plan. One big room, or a few rooms and a bath? So many variables.
Some of the municipalities around here require smoke detectors up to code any time a permit is pulled by any trade for any reason.Here when you do a basement they make you bring the smoke detectors for the whole house up to code (another thing that's good to know).
James, thanks so much for the reply. This info really helps me out. Does this method cover all of the AFCI breakers too. I am using this method for a basement finish. Thanks!Hi Olly
I don't use a spread sheet, just a pretty simple way to get an opening price that's "close enough"
I figure my subcontract rate is approx $90.00 per hour. As a general rule, my average remodeling "per opening" labor is about 40 minutes, or 2/3 hour. So I figure $60.00 per opening for labor.
Next is materials. On the image I posted previously, materials were a lot cheaper, really only about $10 for a standard outlet or switch - $1 box, $1.50 device and plate, $7.50 wire
Therefore, a standard opening was $70
All other openings are based on that, but adding for excess materials. Smoke detector adds $15, can light adds $25, and so on.
As it is now, my standard materials are right $20 mainly because of wire prices at 250% what they used to be.
I'm currently at $80 per opening, but considering going to $85 because now almost all material is 30% higher
Btw, I round up to the nearest $5 on almost every item.
New deck comes with new smoke detectors
Water heater changeout? New smokies![]()
No.James, thanks so much for the reply. This info really helps me out. Does this method cover all of the AFCI breakers too. I am using this method for a basement finish. Thanks!
