M. D.
and this ,... if any care ,.. is 17-152
17-152 Log #1524 NEC-P17
(680-74)
Final Action: Reject
Submitter: Gary Siggins, Underwriters Laboratories Inc.
Recommendation:
Delete from 680.74 the following text: "and providing a means for grounding internal nonaccessible, non-current carrying metal
parts."
Substantiation:
The bonding exception for equipment with an approved system of double insulation if they ground internal nonaccessible, non-current
carrying metal parts is the same as for swimming pool pumps. The pump designs are different. Double insulted hydromassage bathtub
pumps utilize double insulated motors where swimming pool pumps utilize grounded motors with outer plastic covers. Also a
hydromassage bathtub pump is not accessible to the tub occupant. Forcing them to ground the pump would violate the requirements
used to evaluate the motors in UL 1097, "Double Insulation Systems for Use in Electrical Equipment."
Panel Meeting Action: Reject
Panel Statement:
See the submitter's substantiation on Proposal 17-153. The panel believes that a field installed double insulated motor equipped with
a three-wire cord incorporating an equipment grounding conductor provides an increased level of safety.
Number Eligible to Vote: 11
Ballot Results: Affirmative: 11
1597
This ,.. taken from (17-183) the action that lead to the 2005 floors me,... "consicely reworded"?? are they kidding ??
(680-74)
Recommendation:
parts."
Substantiation:
Panel Statement:
1597
Section 680.74 has been concisely reworded
to require the bonding of only the parts that present a risk of creating voltage
gradients in the hydromassage bathtub.
