SiddMartin
- PA
So everyone knows:
I understand to wear the appr. PPE all the time and work everything DEAD all the time, I just want this explained for educational reasons.
I know a lot of you are more educated on this then me, and thus why I ask, Is there a distance to 'live parts' that if not breached would not require the Arc Flash Rating and PPE equip? Here's my example:
Ex: You are adding a breaker in spot #30 in a dwelling 200A 240v Sin Ph., you turn off the main w/ the panel cvr on. Then remove the cover. Since the bus bars are dead, can you add the breaker w/o the PPE req. for exposure to "live parts"? I thought that I heard that if you are not within 2 in. of the exposed live parts(line side breaker/lugs) then the Arc Flash does not apply, but I need that explained to me.
Next question, is it true that if the live parts are 10kIC then you can drop a required Arc Flash rating? (Going from like a #2 which is so many calorie barrier or something, to a #1 which is basiclly hot gloves and glasses.)
I only know a little about this, and need enlightened, thanks for your help!
