mivey
Neat.In the past, we've used a cattle magnet secured to the end of pvc flex.
https://www.amazon.com/Master-Magne...&qid=1538196142&sr=8-1&keywords=cattle+magnet
Works good for Kleins in a wall too.@ days ago one of my men dropped his screwdriver in a 2" pvc conduit. Fortunately, that was easy to retrieve. I also agree a magnet.
Have the magnet through the sleeve before inserting sleeve. Have it just beyond lip so you can push it down when it drags.
Done the rocks, gravel, plaster, and grout that way. Why do other trades like to remove/damage the conduit caps? We usually pig them anyway but I gotta tell ya, we don't get any respect.This. I've extracted tools, parts, even rocks and gravel from conduit and DWV pipe with shop vacs.
Well you gots to hold onto your end of the string chief, at least till you get past the rigid. There is enough room for the magnet to lip around the end of the sleeve.Then it WILL grab the rigid pipe.
Cow magnets are getting harder and harder to find. I try to keep one in every tool box. They make an excellent utility magnet. We use them on the drill rig to check our cutting for metal shavings. It a bad thing when we get metal.
i don’t know how much cow magnets are still used for their original purpose. Years ago when we used steel balance wire, A cow magnet. was fed to every cow. It’s purpose was to catch any stray baling wire that the cow might eat. The magnet would stay in their first stomach and catch metal. The stomach acids would then slowly dissolve the metal wire. Nowadays, everybody used polypropylene baling twine. No magnet needed now.
i really miss baling wire. It was about half again thicker than the tie wire used to tie rebar. You could just about fix anything with baling wire and a pair of pliers. I say a store that actually had a roll of baling wire last summer. But I wasn’t going to pay eighty bucks for it,
Is there already wirenouoled in the conduit ?
Methinks you need to have a long talk with your Tapatalk.Is there already wirenouoled in the conduit ?
Has it worked?
Oh, OK.no. the tapatalk is still broken.
Did you learn why they have that name?Well, I certainly learned a thing today.
Regional farm and general supply store in this area still has them in all their stores. I don't know if that many get put into cows though.Cow magnets are getting harder and harder to find. I try to keep one in every tool box. They make an excellent utility magnet. We use them on the drill rig to check our cutting for metal shavings. It a bad thing when we get metal.
