the problem with blowing a walmart sack through a conduit with forced air, versus sucking the sack through the conduit with a vaccum, is that under the negative pressure of a vacuum, if tied correctly the bag will inflate. what i mean is, if you tie the sack with the correct size of potential "bag", that bag will inflate inside of the conduit under a vacuum, and seal itselt to the sides of the conduit, to run through the conduit as fast as the air will move. when blowing a line, you're using positive pressure and hoping it somehow catches the air like a parachute.
