redhorserider
I encountered a strange problem today. When I turned on a Cadet Heater, the surrounding lights either got brighter or dimmer. At the panel, I checked voltages -- and sure enough, the circuits on the same phase as the heater now read 86 volts to ground, while the other phase read 165 volts to ground. When I turned on another heater, different phase, all returned to a normal 122 volts to ground. This is a single phase, residential system. Since there was no ground rod (!!), I installed 2 ground rods, but it still has the problem. The voltage doesn't float, but its almost as if something is wired in series? Any ideas?
