quogueelectric
- new york
You most definitely have a neutral issue and it is usually on the poco side due to small aluminum conductors old and minimally maintained. I have sometimes had to call as many as 3 or4 times before the poco actually found the problem on thier end.
It is up to the quality of the lineman who they send out. The catch 22 is that it only rears its ugly head under a load. The tendancy is to load up the circuit to see the voltages rise and fall on each side.
What is important is that the problem get fixed asap before it starts a fire. It will damage motor and electronic loads first so remove them from the equation before you start horsing the loads in the house around.
Use only resistive loads like incandescent lights and high ampereage heaters like you are noticing the problem with these are less easilly damaged.
