GilbeSpark
- NC
growler said:You should never reset a GFCI receptacle and just leave. GFCI receptacles don't just trip, there is normally a reason for it. I have found everything from a sprinkler system spraying water on an outdoor receptacle to bad hair dryer cord causing the GFCI to trip. Take a few minutes and find out what they were doing when the receptacle tripped.
If the receptacle is old then change it out for a newer and better type.
If you spend 30 minutes or an hour there trying to solve the problem people don't mind the two hour minimum so much. Always ask if there is anything else you can check out while you are there. Some people will show you a loose receptacle that they wouldn't otherwise bother with. Many of these can be repaired with an box extensioin and longer screws ( 10 minutes ) and now they feel that they have gotten an added service for their money.
Good advice.
