caremedical
- Utah
Hello there :
I am running a large bitcoin data center and wondering about the best way to achieve 240/1 voltage for computers.
I currently have 500 kva transformer that is 12470 delta primay 480/277 wye secondary. I purchased a new transformer for 2500 kva to accomodate higher power in the data center with the same voltages. But all of my computers PSUs are rated for 240 volts. I considered the following options to get 240 volts to the power supply units cost effectively and wondering if there are better options.
1. Use the taps on 480/277 to decrease by 5 percent and use the 263/1 for computers. It is still a bit higher than the voltage tolerance, but I suspect the PSUs can handle this voltage.
Pros : Less distribution wiring cost
Cons: Probably higher voltage can toast PSUs over a long period.
2. Use a second transformer and get 208/120 and use 208 instead.
Pros: PSUs will not get burned. Transformers easily available
Cons: Almost Double wiring cost. Cost of secondary transformer and loss of efficiency by 1-2 percent due to second transformer.
3. Use secondary transformer and 415/240
Pros: Ideal voltage
Cons: Not easy to find these European transformers and takes long time for getting replacement if one fails.
4. Auto transformers:
I wonder if there are autotransformers for 2500 kva range that can adjust the voltage down from 12470 directly 415/240 at reasonable price. ( around 10K usd)
5. Can I buy a 13500 transformer and connect with my utility which distributes 12470 and then using the lowest tap should probably give around 245/1
Any suggestions ??
Pros: Ideal voltage
Any suggestions ??
