Bonding 10 Awg conductor in boxes
Mustwin351
Texas
Wanted to get opinions on how you guys like to bond a #10 equipment grounding conductor in junction boxes and device boxes.
Ground screw and a #10 tail to splice to the other EGC's. If there is only one #10 EGC then connect it directly to the ground screw. If there's a receptacle use a self-grounding device.
I use fork spade connectors to connect the #10 to the box. That makes some inspectors get bent out of shape.
For the most part I install an additional pigtail to connect to the device. Otherwise use a self grounding device if the box is tight.
What's their issue with a fork connector? Proper tooling being used?
SceneryDriver
SceneryDriver
I don't know. I have heard it all and none of them make sense to me:
  • Not designed and listed for grounding purpose
  • Not designed for building wire, they are for fine strand
  • Need to use a regular chair lug
Most of the time when I challenge them they back down.
I have issues with the code on this issue. #10 ground works fine for breakers up to 60 amps. So my #6 cable can use a #10 ground. But my #10 cable cannot use a #12 ground pigtail.. (unless you are me and nobody is looking that close. Nyuck, Nyuck. )
You have issues with all the codes...LOL
"Code is Code
Its OK for someone else
We don't like the rules we don't agree with
if it costs us time and money"
Mike Holt
I would leave the #10 green wire 14" long and strip it in the center and wrap it around the green screw. This way I grounded the box and have a tail to connect to the device or splice to other ground wires.
Pre-tail the boxes in the shop. pitb trying to do it in the field especially with a deep box.
Or you can use a nut driver.:)
Im surprised they don't make #10 ground tails...they are all #12
To each their own but imo those ready made tails, much like "greenies", are mainly a gimmick and another largely unnecessary part to be hauled around. You can simply use the excess egc at the boxes for your tails- roughly the same install time and cheaper too.
installed in an impact driver or drill
Depends on the circumstances. Do you regularly have enough excess conductor at the boxes? Do you have some 12 solid bare readily available - that with some greenies may be fastest with least materials cost, otherwise regardless of what you are using, they cost more if the foreman is installing them then if the apprentice is installing them, assuming the apprentice gets it right the first time.
I prefer to make my own, those store bought 6" tails are just too short for my liking. We use mostly 2 1/8" or 2 1/2" deep boxes and 6" long just doesn't cut it.
When I'm making up quad covers (2 duplex in a raised Industrial cover) triple pig tails really save time.
A lot of electricians feel #12 pig tails are good for #10 :(
