davedottcom
Got a call I was not prepared for! Guy says he will be transferring 180+ proof alcohol from barrel to barrel with a 120V pump. Wants to have everything bonded to prevent any static electricity from causing a Boom!
So...first of all this place is setting up shop in a very basic rental-garage. No idea how the building is classified as far as hazardous fumes go.... I've never dealt with "alcohol fumes" other than on my own breath after a rough day!
Not sure where to even begin...doesn't he need to confirm this building is classified to do what he wants to do? For instance, there is not even an exhaust fan, and none of the existing wiring is inside explosion proof conduits etc...
ugh...
His idea was to simply run a ground wire from the panel to the "pouring location" and provide a means (Ground bar of sorts) for all of his equipment to bond to a common ground via "Cables with Alligator Clamps".
Sounded like a great idea to me at first but...I'm thinking it's a lot more complicated than that!?
ugh...
