Re: Bonding gas pipe to new residential service
Many homes had gas for lighting and heat before running water and electricity.
When I was a child in the 30's, we had only gas as a utility. The old house did not have power until the 40's. We had a hand dug well for water.
When electricity was installed, the gas pipe was the only available thing for an electrode, plus it was a neutral backup conductor. Most gas companies also owned the power company.
The current flow, in the gas pipe, started to destroy the pipe through electrolysis. The gas company started installing the isolating fitting.
The code changed to reflect this development. The gas pipe was an electrode if the fitting was not in place, and could be used as a ground electrode. This permission was retracted in 1990.
Very few, if any, gas services were used for a ground.
The original requirement was to connect to the street side of the meter. The gas company did not approve of this.
The conditions for using the gas pipe, as an electrode, were such that it was rarely done.
In 1990 the code firmly forbid the use of the gas pipe as a ground.
I have the same code books as anyone else. As a matter of fact, I have a complete set back to 1965, and a 1947, and 1940 edition. I have a 1908 handbook.
