yes: 600,800,1000 are used often
a 2 mva 4.5% 53ka with a stiff supply
easily see >40ka on on short hi amp feeders
in utility substations?
once again i will say we are talking about 2 different things, i'm saying 1 cycle is a lot safer than 30 cycles, 15 cycles.
you cannot accurately adjust your impedance of bad bonding connections throughout a ground fault return path, zero is the ideal z to shoot for in this subject matter. i am not disputing the numbers you are coming up with i assume they are correct, those numbers are related to what i am talking about but they do not look at the real world scenario i'm talking about
page 18 http://www.eaton.com/ecm/groups/public/@pub/@electrical/documents/content/td012034en.pdf
16x 0.02 sec
80x 0.006
16^2 x 0.02 =5.1, 1.2 cycles
80^2 x 0.006 = 38.4 , 0.36 cycles
over 7 times as much
but a fault rise is a curve, not a straight line
nor is it's mag, transient, subtransient, steady state
whats the incident energy?
and once again we are not talking about the same thing i'm talking about the difference in 1 cycle and 30
both less than
Incident Energy = 1J/cm2 [= 0.24 cal/cm2 ]
so is it more dangerous to scrape off the paint?
Kind of what I was trying to get at - yes we want higher magnitude to make the device operate as quick as possible, but at same time device is only designed to take a certain level, once you exceed that level, a different device is what is needed or design the supply so that there is enough impedance to keep available fault current below that maximum device rating.for that you just need to have correct ocpd for the available fault current which is already required by NEC. an impeded ground connection should never be considered adding a safety factor in my opinion
ok, let me try another approach
pu values
base: v = 1, i = 1 (ie cb rating), load = 0.8
v drop = 0.05 x 1
z = 0.05/0.8 = 0.0625
i sc = 1/0.0625 = 16 or 1600% of cb rating
inst range
not an issue
if you
comply with code
use listed equipment
install per code, mfgs recommendations, good workman like manner
not an issue
no one said more dangerous, just no advantage, it's not 'less' dangerous
