Jimmy7
- Boston, MA
- Electrician
We installed one of those Arlington fixture siding blocks. The cu in of the block appears to be 6.8. We only have one 14-2 going to the fixture. The owner wants to now install a RAB Gotcha all in one (Pre-assembled two lights and one motion) in that location. On the inside of the RAB cover it states CU4, it appears that is the model number of the cover and not the cubic inch unfortunately. I tried to call RAB to confirm but have been unsuccessful. I know there is an exception in the code in regards to fixture wires that originate within a canopy under #14. I was planning to connect the to the black and white from the canopy. I was also planning on running a #14 to a green screw on the cover to the ground of the 14-2 romex. What about the pre-assembled factory connections of the motion sensor? Do I need to count the pre-assembled connection that terminate in the cover?
