- New Jersey
- Journeyman Electrician (retired)
Those are solid conductors in that panel.
Fortunately I work for people who expect nothing less than the work depicted in the photo. A skilled electrician can do a neat job almost as fast as a slob can do a sloppy job. In my world if your panels looked like a photo taken from a home inspectors forum you would get fired. You get what you pay for. :happyyes:
If you've ever work facilities maintenance you learn very quickly that you use existing conduits when you can, you use existing circuits to pull with, you sometimes find a circuit simply by tugging on it, you have to move circuits around in panels for various reasons or you simply need to know which conduit something is coming out of.
When you use stranded wire, the only way to get it to look like those pics is to use tie wraps. If you pull solid wire you can still make it look like that and and you don't have to bundle the wires all together. I've also know that a lot of guys that bundle their wire like that, pick on the west coast guys for using only one two inch KO to bring in all of their home runs in resi panels.
What is the metal between the two panels where the feed through conductors are?
John, sorry to impose on you by leaving the tie wraps on. I figure the next guy is just as capable o clipping them off as I am.![]()
If I could be king I would issue a decree, "Cease using cable ties in panels!"
Horsegoer- The difference between solid and stranded is a matter of degree. Both can be shaped. The difference is solid can be shaped in hard, ridged, unyielding angles like a East European prison guard. When working with stranded shape can still be defined but it flows and turns gently, much like the curves one finds pleasing when casting a gaze on an eye catching gal.
I'd rather take my side cutters and clip the tie-wraps than untwist short pieces of wire some use to tie the conductors together!:thumbsup:
How many of you here remember using serving twine? Now that is art!
I remember it!
Tied a few cables down with it but mostly watched AT&T and Verizon guys use it when they were laceing their cables.
Always looked good!
To add to the previous post. if it states or has specific details in the slec book about how panels should be made up. we had one last year at Cisco systems. we have 1 or 2 men that do nothing but go from panel to panel " making them pretty" everything is there. All the wire s pulled, labeld. but this cost is picked up in the estimate and accounted for.
I didnt mean to offend anyone and i just noticed that this is for a larger project or larger company strictly due to the bushings on the conduits that do not contain wires of #4 or larger. Thats usually a definning characteristic of a bigger operation that anticipates the time it takes to make those panels look so well. I think I may be biased against them for one other reason besides they cost me money is because when I was that journeymen in the field years ago with the big outfit I could never get them to be that nice. almost close but not really. Awesome
This is not something that always happens here, but a couple of inspection departments in my area would not accept this installation when the bundling is longer than 2 feet and violates the number of current carrying conductors. I have gotten in the habit of making a panel look neat (though nto as neat as depicted here) without tie wraps in the final product.
I had no idea it would be this easy.Long live the king!
No tie wraps in panels, the king has spoken!:happyyes:
