Sierrasparky
- USA
- Electrician ,contractor
Is it ok to place an breaker panel in the wall of a garage seperating the living space from the garage in a single family residence?
I did a similar installation, Panel was relocated from the laundry room to the garage
interior wall. It passed with flying colors. A disconnect was required however,
because it exceeded the maximum allowed length of unprotected service conductor. Which is 10 feet or as close as practile.
Passing does not necessarily mean compliant with the codes.
I see. So what is the code for the rest of california.
Hi Edward,I have done installations where the city required the back of the panel be wrapped with fire pad in order for that panel to be installed in a wall sharing with the garage and the living space. And other cities have never brought up the issue.
So, i think it would be better if you check with the city. I am sure you will agree that there is nothing worse than redoing a job.
