MTW
- SE Michigan
In my shop, I use two single Φ 4 winding transformers in an open delta configuration supplied by 240 delta to produce four 3Φ voltages for testing motors and equipment. 120, 200, 240, 480V. The idea came about from being asked to reverse engineer and repair an old hand built motor test stand that the motor shop had acquired from another shop.
I like the idea so much, that I built one for my own use for testing equipment and motors. Their shop supply was 480V, mine was 240V so there were some differences to the connections. What I added to my test board was a bunch of relays and contactors to be able to switch the voltages on the fly. Starting a large motor sitting loose on the floor at full voltage could get it to take off rolling across the shop. Starting at lower voltage and ramping it up on the fly solved that problem. It's the only time I ever come across 3Φ 120V. I thought about adding a 600V option to it since I'm not far from Canada, but it's complex enough as it is, with it's contactors. For 600V the few times I need that, I will drag out another transformer to connect to the mix. Sure is convenient for testing versus connecting up a separate transformer for each thing that need to be tested at a different voltage and repaired.
i supplied the motor shop with a drawing of their old unit, and they built a new larger version for their own use, they had a slotted machine table cast into the floor to bolt their motors down to. A much safer setup for the size motors they fired up. Auto transformers can be a versatile tool.
