tallgirl
- Glendale, WI
- Controls Systems firmware engineer
This thread got locked before any good answers were given:
Here's another without a lot of answers:
Here's one for burying a junction box:
Basically, there aren't any threads that cover what I want to do, so I figure I'll describe it and reference some code sections (2017 NEC for Wisconsin). And then there will be a thread.
I want to have a built-in hutch in a piece of wall that's weird-shaped and either needed to be an enclosed void, or I could fill the void with this hutch. I could either do all the construction in-place (then it's not an issue - it's a wall that's shaped like a hutch), but I don't think I can do the cabinetry as nicely - shelves and cabinets with doors - as if I built is separately, then slide it into place and connect the wiring.
The relevant code sections are 210.52 (A) (2) and 314.29 (and maybe 300.4 (D) and 300.23). I can use a 4" recessed LED light (one of the pancake lights) below the junction box in the top of the hutch and a 6" high decorative trim board with screws which are meant to be removed for access. The plan is to use Wiremold (this is for 300.4 (D)) on the outside of the sides of the hutch, with a Wiremold junction box having a receptacle and snap switch for the overhead light. The LED driver will be in the space above the top of the hutch (300.23).
Build all of that in the middle of the floor, do all the wiring before sliding it in place and screwing it to the walls, then connect the wires on the top into junction box in the ceiling, put the LED into the hole for it, put the cover on, and call it good.
How's that sound?
Custom furniture
I have a client that has installed custom permanent furniture in their office. Internally they snaked Wires through the various tiers & installed Table lamps(4 looped together ) with zip cord & are plugged into a receptacle I installed underneath. I’m looking at 400.8 to convince the client...
forums.mikeholt.com
Question
What article(s) of the NEC cover powered furniture, like tables and tool boxes with power strips/built-in receptacles?
forums.mikeholt.com
Concealing a JB exceptions?
With respect to NEC 314.29, is there a way to conceal a junction box if it doesn't contain a splice? Or is there a product that can make a junction box be considered a raceway? I've seen those plastic sleeves that can guide a wire through a JB when pulling, but something along those lines...
forums.mikeholt.com
How's that sound?
