Re: Bundled = Derated
George
It is not often that you completely agree with me
820.52(A)
(2) Other Applications. Coaxial cable shall be separated at least 50 mm (2 in.) from conductors of any electric light, power, Class 1, non?power-limited fire alarm, or medium power network-powered broadband communications circuits.
Exception No. 1: Where either (1) all of the conductors of electric light, power, Class 1, non?power-limited fire alarm, and medium power network-powered broadband communications
and circuits are in a raceway, or in metal-sheathed, metal-clad, nonmetallic-sheathed Type AC or Type UF cables, or (2) all of the coaxial cables are encased in raceway.
Exception No. 2: Where the coaxial cables are permanently separated from the conductors of electric light, power, Class 1, non?power-limited fire alarm, and medium power network-powered broadband communications circuits
by a continuous and firmly fixed nonconductor, such as porcelain tubes or flexible tubing, in addition to the insulation on the wire.
This permits those cables to be installed in the same bored hole as NM, AC cables, etc....
From Bryan
Using the definition of "bundled" in Article 520, which I have proposed to be moved to Article 100, the picture does not appear to be bundling, unless you consider "periodically bound together" the same as running through bored holes, which I do not.
From CMP in the '05 Report on Proposals.
1-67 Log # 1601 NEC-P01
(100-Bundled (New)) Final Action: Reject
Panel Statement:
The definition belongs in Article 520. Its use in Article 310 is largely unrelated to the Article 520 definiton.
I am not too sure I understand or agree with the reasoning
